General LSX Automobile Discussion Non-technical LSX related topics.
Need help w/my silverado!!! Wont Start??
Old 01-12-2013, 10:16 AM
cubezilla's Avatar
Question Need help w/my silverado!!! Wont Start??
got a 2000 silverado & i put a 6.2ls3 in it about 6months ago and all was fine.
I dont drive it daily so it sat for about 2 weeks, and i keep a battery tender on it, so when i went to drive it , the engine started but very slowly as if the battery was dead, truck ran fine but when i parked it again i had nothing from the engine, radio,headlights,fans,cluster all work and where lit up but the engine wouldnt start...
Now, this morning i checked my grounds, all are fine..
1. Replaced battery with a brand new one
2. Replaced starter with a brand new one
3. Replaced the Ignition switch (wiring harness) with a brand new one
I turn the switch over and the engine may spin over very little if any then (Click Click Click)
I put a booster box on it an it fires right up, and runs fine!!!! Cut it off and same thing...... Click Click Click ????
I'm completely lost???
cubezilla is offline
Old 01-12-2013, 10:44 AM
nomasterase's Avatar
If it starts normally with a booster pack but not with the battery theres most likely something wrong with the connections or the battery is not up to the task. I know you say its new but that doesnt mean its good maybe you should have it load tested
nomasterase is offline
Quick Reply: Need help w/my silverado!!! Wont Start??
