Pennzoil "Ultra" and ZMax....
Don't know if anyone has tried this yet.... and I am not one to fall into "Hype", but since I switched to Pennzoil "Ultra" Now full time and adding ZMax my gas mileage has gone from 19.5 to 19.9 mpg. That may not sound like a big difference to some but there is still something to be said for that. I have been using it now for awhile and the result has been a positive one IMO. Not saying that the other brands used before were bad they have all been great: (aka: Lucas Oil, Pennzoil "Platinum", Mobil 1 for ex.), However I switched to Pennzoil "Ultra" about 6 oil changes ago on my '06 Ford Mustang GT Coupe (Modified)... (yes you read right see my new member intro.) and that has been the result. Started to see results in the 1st oil change just for the record.
Thanks.
(I was reading posts about high mileage LS cars and since I had been experimenting with the ZMax and "Ultra" synth. figured I would share the results.)
Thanks.
The ZMax you add every 6k miles not at every oil change (Unless you change oil every 6k miles). Just on the 1st oil change I watched my avg. go from a steady 19.5 to a 19.7 after 2k miles (not enough to make me really exited). By the 3rd oil change and second dose of ZMax it pretty much went to a steady 19.9 mpg. All I know is the proof was there... and that is all I needed.
zmax and royal purple
I just changed my oil royal purple and this time decided to use zmax for the first time,. I have an after market k member with solid motor mounts and after zmax it seems to be a lot smoother throughout the RPM i did a 140mph run before having to slow down and it was the smoothes yet. I highly recomend it you have to get the car hot before dumping it in tho.
