98 vs 99-02 Fbodys maf and map
I've searched around to find the differences in the 98 vs 99 and up cars but I can't seem to find a solid answer. I know the differences are the 98s had speed density, perimeter valve covers, no coil brackets, 806 heads, some of the wiring is different etc. My main question is did the 98s have a maf and no map or vice versa? The reason I'm asking is I always thought speed density tuning was no maf. I looked at my first 98 car yesterday and i seen it had a maf sensor. I was shocked. Is it that a speed density car had the maf but no map on these cars?
Different:
ECU
ABS system
Valve Covers
Sleeves in the block are thinner (thats why 98s is more prone to piston slap)
larger injectors
Late 98s have c5 cam
98s do not have ls6 intake
i think thats most of what is 98 specific
ECU
ABS system
Valve Covers
larger injectors
LS1Tech Administrator
Received 1,796 Likes
Check out the FAQ sticky in the Newbie Tech section for further details on the differences. https://ls1tech.com/forums/new-ls1-o...questions.html
ABS system
