General LSX Automobile Discussion Non-technical LSX related topics.
Need 4th Gen Camaro Logo For Double DIN Wallpaper
Old 11-27-2014, 12:46 PM
BandDirector Blk98ZM6's Avatar
Default Need 4th Gen Camaro Logo For Double DIN Wallpaper
I just got a double DIN Pioneer HU (AVH-X2600BT) for my '98 Z28 and it has the capability for me to add my own wallpaper to the home screen. I want to add the 4th Gen. Camaro Logo, but I need the background to be black and the actual letters to be silver (or maybe blue)...all I can find is the white background with black letters. I have NO experience with photoshop, etc., so can anyone point me in the right direction to find or make what I need? I'm attaching 2 examples. The first is the 4th Gen. Camaro logo I want, and the second is the 5th Gen. logo similar to what I'm looking for in a 4th Gen. logo.
Attached Thumbnails Need 4th Gen Camaro Logo For Double DIN Wallpaper-camaro-logo-4th-gen.jpg   Need 4th Gen Camaro Logo For Double DIN Wallpaper-camaro-logo-5th-gen.jpg
Old 11-28-2014, 01:25 PM
99Bluz28's Avatar
Have you tried creating your own..?
There's numerous website that allow you to do it with your own digital photo's.
Old 11-28-2014, 06:07 PM
FirstYrLS1Z's Avatar
I've got the entire alphabet in Camaro font,created them. I used them for my 2008 and 2009 calendars.
what size is the screen area(" x "),what format is usable,such as jpeg(or other) ?
I should be able to create in Photoshop whatever you need and email them to you.
here they are in low resolution
like this
Old 11-28-2014, 11:15 PM
That's EXACTLY what I'm looking for! The screen is a 6.1" screen and I need the format to be .jpg I saved the image you posted and I'm going to see how it looks. I was thinking I either wanted "CAMARO" in blue to match the button illumination color I plan to use, or red to match the badge on the trim bezel, or silver to contrast the blue illumination. I'm going to start with what you posted and I'll be in touch to let you know how it looks. THANK YOU!
Old 11-29-2014, 03:03 PM
Same blue on black with red neon glow
or
or
what is screen size inches by inches ?
Old 11-30-2014, 05:04 PM
THANK YOU FirstYrLS1Z! You're really hooking me up! To be honest, I really like the first one you posted! My goal is to make the Double DIN touchscreen look stock and I think Chevy would have done something like just the basic "CAMARO" logo on the opening screen like you did with your first option. I need to get the thing installed before I can say what color I need for sure and also the placement of the logo. When the radio is off, the home screen with this logo will be displayed, but I did notice that the clock is in the upper right hand corner, so the logo may have to be moved down just a tad so the clock doesn't block it...however, I won't know for sure until I get the thing installed. I was working on it today and discovered my DoubleDMods Metra kit leaves a little space above and below the HU, so I now need to order a trim ring to make this work...another delay
Anyway, here's everything I know about the screen. It's a 6.1" screen that actually measures 2 3/4" x 5 5/16". It's a 16:9 widescreen. The resolution of the display is 800 x 480 (RGB), for a total of 1,152,000 pixels.
I really think I'm only interested in one of 3 colors for the logo, all with a plain black background. Either blue to match the rest of the HU's illumination buttons, red to match the camaro on the trim bezel, or silver (maybe even chrome) as a contrasting color to everything else. Like I said, the first one you posted is really exactly what I was looking for!
Old 11-30-2014, 05:18 PM
I've been making the 'tests' at 640x480x72.
The 2 3/4 x 5 5/16,16x9,800x480 RGB,1,152,000 pixels gives me definite data to work with.
Old 11-30-2014, 06:31 PM
here's a 800x480
I can lower/reposition/shrink the text,make the blue lighter/darker based on what you want when it's viewed in bright and/or dark conditions.
Old 11-30-2014, 06:41 PM
THANKS! Saved it and I'll see how it works. It'll probably be a few weeks before I try to install it again...I like to have everything I need when I start a project
Old 12-14-2014, 12:49 PM
...just a quick update...I ordered a "genuine" Pioneer trim piece that was SUPPOSED to fit my HU exactly (as was advertised on eBay), but when it arrived, it still left a gap. I've ordered 2 more trim pieces to try, but they're coming from CA to GA during the holiday season, so things are moving slow...
I can't wait to get this project going!
Old 09-01-2018, 02:34 PM
Originally Posted by FirstYrLS1Z
here's a 800x480
I know...talk about reviving an old thread, but I actually just got around to installing the Double DIN Pioneer at the beginning of the summer. I loaded the above image and it still wasn't big enough for the 6.1" screen. I had about a 1/2" left on each side of the wallpaper and just a little bit left at the bottom. The "CAMARO" logo is the right size, I just need more of the black boarder. Any chance you can make it any larger for me? It will really look good once it fills the whole screen!
Thanks man!
Old 09-02-2018, 10:53 AM
bammax's Avatar
Open the file on Microsoft paint and you can extend the black or stretch the image. Extending the black is just a matter of setting a work space size and centering your current image in it. Then copy the black and fill the edges of your work space. Save the file as jpg and you're good to go.
Old 09-02-2018, 12:45 PM
Thanks! I've been working with it for about an hour or so and can't make it fill out the screen. After some research, seems to be a common issue... I've just got to keep playing and hope I stumble on the right size eventually...
Old 09-02-2018, 02:24 PM
bammax's Avatar
I've found when it comes to that kind of stuff it's lots of trial and error with a little dumb luck mixed in.
Old 09-04-2018, 08:28 AM
Ungrounded Moderator
WhiteBird00's Avatar
Pioneer's documentation says that images up to 2048x1536 can be used for the background - the HU will scale the image down as needed. So you might have better luck making the image bigger than needed and let the HU handle it rather than gradually trying larger sizes until it fits.
Old 09-04-2018, 08:01 PM
I saw that too, but when I tried to make it that size in Paint 3D, it wouldn't let me go that big...
Old 09-13-2018, 10:17 AM
Just saw the revival of this thread from 4 years ago. I'll make one 2048 x 1536 without increasing the Camaro logo size.
Old 09-13-2018, 10:35 AM
try this one.
Old 09-14-2018, 01:48 PM
try this one.
Thanks! Unfortunately, it loaded the exact same way as the original picture. I have no idea what the trick is to make this Pioneer use the whole screen... I've resized and made it go edge to edge, but then it leaves gaps at the top and bottom... I just can't figure it out yet...
Quick Reply: Need 4th Gen Camaro Logo For Double DIN Wallpaper
