General LSX Automobile Discussion Non-technical LSX related topics.
Using 4x4 pcm + harness in 2wd truck questions
Old 10-02-2016, 11:28 AM
Diesel_Zuk's Avatar
Default Using 4x4 pcm + harness in 2wd truck questions
Hey folks, I have a 2004 Silverado roller I bought for dirt cheap, PO pulled drivetrain for his Chevelle project. Anyways, vin indicates it was a 4.8. I'm looking for an engine and harness to put back in. Problem is, around here the only ones I can find are 4x4. I thought the vss on the 4x4 was on the transfer case. Can I just run a 2wd 4l60e and disconnect the vss and tcase plug? Or do I need to do anything special? Thanks for the help.
Old 10-03-2016, 04:39 PM
N20zuki's Avatar
You need the VSS for the PCM... the PCM's are the same 2wd and 4wd... harness is the same essentially except 4wd had more wiring but it can be removed from the harness with no issue
The following users liked this post:
TheeMatrixHasYou (08-26-2020)
Old 08-26-2020, 12:38 AM
TheeMatrixHasYou's Avatar
Default 2003 Escalade AWD to 2WD for LS Swap
I’m looking to put a 2003 6.0 Escalade into a 66 Cadillac and need a 2WD.
three videos later, I believe I need a 4l65e not 4l60e. Also what to do with the plugs from the transfer case will this setup (cruise control-proper shifting etc) work without them?
note: I’m taking everything out of the Escalade
steering wheel/column, interior /exterior wire harness, dual ac system, pedals etc. it’s a DeVille not an Eldorado!!’
Last swap was a 1964 C10 upgraded with a 2wd 911500(had to drill holes and mounted the steering gear box on the outside from a 1987) suburban gas tank- factory 91 a/c.
Old 08-26-2020, 12:47 AM
Default Ls swap 2003 6.0 Escalade AWD into 2wd
Three questions
so would I purchase an adapter for the 4l65e to connect the speedometer cable to keep the interior dash original?
Will I need to do anything to the PCM since all the Bells and Whistles would be gone stock for the 2003 Eacalade
how would I get cruise control if I went this route?
i have a complete donor car
separate post below
Quick Reply: Using 4x4 pcm + harness in 2wd truck questions
