General LSX Automobile Discussion Non-technical LSX related topics.
Here's a couple new products that will keep unfiltered oil from getting in your bear
Old 03-19-2017, 07:35 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default Here's a couple new products that will keep unfiltered oil from getting in your bear
SacCityCorvette's
Precision LS Billet Barbell and other Oil System Improvement products!
The Oil Galley Barbell in your LS based engine is something that is over looked. And yet it serves a very important mission of directing oil to the oil filter. If oil leaks past the Barbell it will go unfiltered directly to the Cam Bearing, Lifters, Crank and Rod Bearings. (See Diagram Below) The factory Barbell is approximately .020” to loose so particles as big as 500 Microns can leak past the factory Barbell. Your oil filter will filter out 15 to 25 Microns depend on the brand of filter. Our 6061 Aluminum Precision Billet Barbell fits with approximately .001” clearance which will let only about 20-25 Microns pass by, that same as the filter.
Another important part is the shaft of the Barbell. The oil has to flow around it to get though the oil port. Our Billet Barbell has a 30% smaller shaft for much less flow restriction.
We have also added a 1/4-20 threaded hole in the end of our Barbell for easy removal. Just screw a 1/4-20 bolt in and pull the barbell out. No more digging and prying to get the factory one out.
Better engine protection from much less and smaller particles bypassing, smaller less restrictive shaft for better oil flow, replaceable High Temperature Viton O ring and for ease of service a threaded 1/4-20 hole.
Why would you ever put the plastic factory Barbell back in your expensive LS engine build?
See Our other Oil System Performance Improvement Products below.
Fits LS1-2-3-6-7-9-LQ4-LQ9-4.8L-5.3L-6.0L-6.2La and more!
Also, available for the new Gen 5 LT1/LT4!
Only $26.95 Free Shipping
http://www.saccitycorvette.com/Billet-BarBell.html
Here you can see how the unfiltered oil gets by the loose factory Barbell. Also you can see how our Barbells smaller shaft will improve oil flow!
Check Out all 4 of our Oil System Improvement products!
If you don't know much about how the Barbell works check out video.
Video of how loose the factory Barbell really is compared to our billet Barbell.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 03-20-2017, 11:56 PM
ragz's Avatar
Just ordered , looks like a good upgrade for my ls3.
Old 03-21-2017, 11:47 AM
LS1Tech Sponsor
Thank you for your business ragz, we really appreciate it!
We will get it right out to you!
Christian
__________________
Old 01-20-2018, 10:52 PM
LS1Tech Sponsor
We have the the Billet oil system improvement parts in stock when you need them.
__________________
Old 10-16-2019, 12:06 AM
LS1Tech Sponsor
We have all these Billet Parts and the AlignIt Tools in stock and ready for same day shipping!
Billet Oil Improvement Parts, Help unfiltered oil out of the bearings and lifters.
https://www.saccitycorvette.com/OilS...provement.html
AlignIt Tools, get the rear Main and Timing Covers perfectly aligned with the crank and prevent leaks and premature seal failure!
https://www.saccitycorvette.com/AlignItTools.html
__________________
Old 10-18-2019, 02:41 AM
sjsingle1's Avatar
but my bear likes unfiltered oil
Old 04-23-2020, 02:00 AM
LS1Tech Sponsor
We hope everyone is doing well and staying safe during this crazy time of the virus.
Just wanted to let you know, while we are practicing the virus safety precautions, we still have our same day shipping of our products.
Stay safe and let’s get through this!
Christian
SacCityCorvette
__________________
Quick Reply: Here's a couple new products that will keep unfiltered oil from getting in your bear
