Where is the Restriction
OK I was at a car show this past Saturday and I saw a guy with the Fast 90/90 setup and a stock MAF. How are you going to see a big gain with the Air is still going through 75mm MAF? I don't see a point in the Fast 90/90 unless people upgrade the MAF and LID with bigger opening. What am I missing?
Moderator
You're missing that it's a series of "soft" restrictions,
not trying to fit a hard object through a fixed hole.
Remove what you can and leave what you can't.
The MAF (minus the "screen", which sucks) is a short
bit of smooth pipe and doesn't drop much pressure
at flows where it's still a useful instrument.
With manifolds you have each cylinder drawing a
big narrow pulse so it needs runner size during the
pulse, and otherwise it's wasted volume. But out in
the plenum and forward it's a smoother, averaged
flow and one 75mm hole can "support" 8 75mm dia
runners pretty much if each is drawing 1/8 of the
time (or effectively).
Also remember as the air goes thru the MAF the airflow velocity will increase so the flow rate will remain pretty constant.
Bigger MAF's tend to show a cripser throttle response as opposed to massive HP gains.
480rwhp from a 75 to an 85mm MAF would probably see ~5rwhp +-3rwhp.
