Oil and Gas
Premium gas(91 or 93 octane, whichever you have locally), oil is a personal preference. Most say Mobil 1 recommended by the factory is too thin. Patman seems to know quite a bit about oil, maybe do a search for his name.
will it hurt the car? no. It's is designed to run on lower octane for emergency. Knock sensor pulls timing and richens fuel flow.
will it hurt performance? yes 10.1 to 1 compression ratio creates too much heat during compression stroke to not start burning before the piston reaches tdc. This is knock.
