What is typical oil pressure?
I did a search and didn't quite find what I needed. On a cold start my pressure is at 70ish and while cruising it won't drop below 50psi and that's if it's warm outside. It usually is always at 60-70psi and pretty much tops out the gauge at WOT. Is this normal? I don't know what kind of oil is in it, but it's fresh.
High oil pressure is good, too much or too little oil pressure means something is wrong.
