slp manual fan cantrol switch
hey whats up everybody? recently i bought the slp fan cantrol switch and installed it. will anything happen to the fans or something else, if i turn on the fans at 160 degrees and leave it on while im driving around. of courst ill turn it off when i turn off the engine. thanks
Why would you want to do this? A cool engine is good, but a cold engine would be overkill and give poor performance. I would also say running the fans at all times would wear them out faster.
I've had to change my fan twice so far. I think the first one was a bad fan anyways and so was the second cause I got it from the junkyard. But I bought a new one and this time it's been working great for about a year I believe. But as long as it's hooked up right and there is no chances of wires touching (which is easy with small toggle switches) then it should be fine cause that's all it does when the fan gets turned on anyways. I only put a switch in mine cause my relays stopped working or something and I couldn't figure it out even after putting new relays and fuses and so on in.
BTW I got almost 204k.
