Sponsored by: CARiD
Cooling system flush... AGH
Old Oct 9, 2008 | 12:14 AM
TireSm0ke's Avatar
Default Cooling system flush... AGH
So I did a cooling system flush today, bought a jug of orange dexcool, water wetter, and a couple jugs of distilled water. I drained the radiator, stuck a hose in the top, and ran the car for a bit on and off, id say a quart at the most drained from the radiator, I thought it would be more. Then I started running the hose through it to flush it out and only clear water was coming out the bottom, the thermostat should have opened and closed by then? The car took barely took a gallon of dexcool... What am I doing wrong? theres alot of crap built up in the filler neck so I need to flush the hell out of the entire system, can someone tell me exactly how to do a thorough flush? Thx
Old Oct 9, 2008 | 12:46 AM
LS6427's Avatar
Your t-stat most likely never opened and the coolant in the block and heads never moved. It takes a good 10 minutes for the t-stat to open if the engine is cool. If you're putting fresh water right into it it'll keep it cool.
The best way to flush your system is to remove the t-stat and bolt the housing back up. Then stick the hose in the radiator with the plug open at the bottom of the radiator and run the engine for 10 minutes. This way you will get every single drop of old coolant out. But take the entire pet **** valve off so the coolant runs out of the radiator faster, otherwise it'll take forever for the water to run clear.
If you want to, get a bottle of radiator flush. After the water is nice and clean after the first 10 minutes, close the plug and let the engine run with the flush in it for another 10 minutes. Then open the plug and run it for about 5 minutes and let the water and flush run out of the system. Your done.
Old Oct 9, 2008 | 04:01 PM
1 FMF's Avatar
if the thermostat is in then you really need to have the radiator cap on so the system pressurizes which will help the coolant or water flow through the system.
and draining by the radiator petcock only leaves a lot of fluid in the block, you really need to pull the block drains- one above the starter that'll use a 5/16" allen and there's a 16mm allen near the alternator, both are brass colored. Otherwise you're refill of coolant/water mix will be way off- 50/50 + however much water left in the block = < 50% coolant and > 50% water in the system.
If you can't get the block drains, then I don't know if parking on a downsloping angle will help at all at the radiator petcock, only other thing i can think of is compressed air to blow through the system, or a special coolant flush/change machine that forces fresh coolant through such as at a radiator shop.
Old Oct 9, 2008 | 11:07 PM
LS6427's Avatar
Thats why the t-stat should be removed. Radiator cap left "off". Radiator allowed to drain completely. Then stick a running hose on full blast in the radiatro cap constantly with fresh water. Petcock completely opened up, not just loosened, but the whole plug removed. 10-15 minutes of the engine running will get every drop of old coolant out of the entire engine block and heads, it will run clear after about 15 minutes.
No pressure is needed in the cooling system for the water pump to push water through the system.
Old Oct 9, 2008 | 11:42 PM
SparkyJJO's Avatar
I may end up having to do this on mine at some point. Looks downright disgusting in my radiator.
Old Oct 9, 2008 | 11:57 PM
Blazingz28's Avatar
yea my overflow looks kinda nasty.. I have 123k.. but only reason I havent flushed is because.. "if it aint broke, dont fix it"
My car has never overheated once since 1999
Old Oct 10, 2008 | 12:59 AM
samson_420's Avatar
When I did my flush, I removed the reservoir and rinsed it out. Then flushed the radiator and all the other crap with hose water for about a half an hour.
When I was done the water was crystal clear.
Old Oct 11, 2008 | 10:36 PM
TireSm0ke's Avatar
How do you remove the reservoir? Its under the battery isnt it?
Old Oct 11, 2008 | 10:42 PM
samson_420's Avatar
Take the battery out, then it's only one bolt.
Old Oct 12, 2008 | 03:07 AM
Grimes's Avatar
The easy and "lazy" way to do it is to just drain the radiator once a year, and fill that up. Been doing that for a long time, and it's just enough to "refresh" the system, and not be a total pain in the ***.
Old Oct 12, 2008 | 10:55 PM
Black 99 Bird's Avatar
Are you guys putting dexcool back in? I put the green stuff in mine because of all the bad press the dexcool gets.
Old Oct 12, 2008 | 11:09 PM
W.hiteS.6's Avatar
better have made sure u got all the dex out b4 puttin in the green. very bad to mix. btw unless youre the engineer that designed the system i suggest u stick with dex. people put in alot of time and effort to firure out what works and what doesnt...
Old Oct 12, 2008 | 11:18 PM
sweetbmxrider's Avatar
grab one of these and drain your radiator, close the petcock, then pump it up to the pressure on the cap, then open the petcock and watch out. couple times should get everything out.
i would stay away from the flush additives too.
switching from dex-cool to green is a bad idea as well. they use different gasket materials. you are asking for leaks.
Old Oct 13, 2008 | 08:21 AM
Yes all the dexcool is out, and 70K with no leaks.
