Emissions Help
Old 10-21-2008, 04:57 PM
bowtiekid's Avatar
Default Emissions Help
Ok, I pulled the engine harness out of my 95 and went through it very throughly*sp*? and found quite a few frayed wires and connections. I also fixed the EWP switch and wired that a bit neatly.
So after that and replacing the PCV valve and hose these are my new test results:
My Car: HC: 1.76 Limit: .80
My Car: CO PASS
My Car: NOX: 4.19 Limit: 2.00
Throwing no codes, only thing is the ABS light comes on but thats it, and it only does it at the testing place for some reason. SO what should be my next step??????
Thanks in advance!
-Mark
Old 10-21-2008, 06:28 PM
bowtiekid's Avatar
Ok a little update.
Exhaust is as follows Pace Setter headers, Cat, and exit before rear tire. I have a cat per bank. The exhaust exits one pipe on each rear tire. Oh and NO EGR
Also I extended the 02's myself from the PCM side and Im using brand new Denso 02's
I lost 2 of the 4 TB bolts so I dont knw if thats causing a leak or not but theres the info. Just trying to help get some info so I can get tags.
Thanks
-Mark
