ASR button light
Old 10-24-2008, 08:50 AM
z28pat's Avatar
Default ASR button light
my Asr button's light is out and I'm not sure what bulb goes in there . Does anybody know?
Old 10-24-2008, 02:16 PM
joshp14's Avatar
I'm sure the bulb inside isnt meant to be serviced. Meaning if the bulb goes out, the switch must be replaced. You can try to take it apart and see what it takes to replace it, but you might be better off buying a new switch then fiddling with a tiny bulb that may even be soldered in place.
You might make sure that the pink wire that goes to the switch has power before you replace the switch or try to replace the bulb.
