Coil packs
Well I could be wrong, but essentially every coil pack is a transformer. so two leads should be a primary inductor/coil and two leads should be the secondary inductor/coil.
If you knew which leads were which, you could place an ohm meter across the inductor to see if there is an open (coils read as shorts to DC) , other than that I don't really know what you could do.
Does Autzone have a contraption to test coils like they do alternators and batteries?
You can measure resistance of the primary and secondary ignition. I don't know the specs though but go across the harness part (primary) with an Ohmmeter, then go from the coil electrode to one of the harness pins for the secondary.
