replacing lifters
Old 10-30-2008, 08:10 PM
coryprine's Avatar
Default replacing lifters
is it difficult for someone to change lifters? i am mechanically inclined but have never attempted internal engine work before...
Old 10-30-2008, 08:19 PM
1lejohn's Avatar
You have to pull the heads. Its a big job if you never done it before. Are the lifters bad?
Old 10-31-2008, 05:47 PM
coryprine's Avatar
yea constant ticking noise and 99 percent of ppl whos heard it says lifters
Old 10-31-2008, 06:13 PM
chavez885's Avatar
I changed my lifters by pulling the intake and valve train off. Not sure if you can get to the lifters on LS1's by pulling the intake.
Old 10-31-2008, 06:14 PM
Benner's Avatar
No ls1's you have to pull the heads.
Furious_George's Avatar
do you have LT headers? sometimes they will make the tick sound louder....also if you have an exhaust leak at your header gaskets, it could sound like ticking lifters. what year is it and how many miles? and what type/weight of oil do you use? just brainstorming other things it may be because it's kind of a pain in the *** to change lifters in these cars. and it costs a decent bit of cash too when all is said and done. but if you're sure that's the problem, there's a great writeup here: http://ls1howto.com/index.php?article=2
just don't worry about all the stuff about the cam, unbolting the radiator, harmonic balancer, or most of the other stuff. if you have any spare cash, it would be a great opportunity to toss in a new set of heads and a cam too. good luck with any way this goes.
