Oil Change Light
Old 11-04-2008, 09:58 AM
GreenBlood's Avatar
Default Oil Change Light
Ok, so sometimes after I change my oil, my car will be fine for a few days, and then randomly, the orange Oil Change light comes on when I first start the car. After a couple of minutes it goes away. Any reason why it does this? Its only been 2 weeks and 800 miles since I changed the oil with German Castrol 0w-30 and a K&N oil filter...Should I be worried about the light?
Old 11-04-2008, 10:15 AM
keliente's Avatar
You need to reset the light manually, it does not know when you changed the oil. Turn the key on and hold the trip counter reset button for 12 seconds or so, that will reset the light.
Old 11-04-2008, 11:56 AM
GreenBlood's Avatar
ok, thanks
Old 11-06-2008, 12:03 PM
TAtoad's Avatar
the gas pedal method worked on my car to erase the light. also on a buddys z28
Old 11-06-2008, 08:46 PM
ghardester's Avatar
It is also not a measure of how dirty your oil is or how many miles have passed between changes. It is a simple count of start cycles that attempts to predict when you should change your oil.
Old 11-06-2008, 08:52 PM
ae13291's Avatar
i only seen my oil change light once. i dont usually reset the light after an oil change, but mine has not come on yet? is it broken
Old 11-06-2008, 08:57 PM
johnLs1camaro's Avatar
well before i have never seen mine come on, and i drove the car for probably 10000 miles and then i was pulling the starter and broke that damn sensor, and now it will just come on at random times...so idk..
