spark plug help
spark plug help
whats up everyone? im going to change my spark plugs and plug wires on my v8 00 trans am.
wanted to know if ther is an esay way to change the spark plugs. also are all the plug wires the same or is there some shorter than others. i know i have to change the plugs and wires one by one. i bought some tyson plug wires and the all look the same will it matter which one i put on. thanks in advance.
the plug wires are all the same length, and the only really "easy" way to change out the plugs would be in the motor was out of the car. be prepared for some scraped up hands, take your time and if you get frustrated step back and take a break for a minute. patience is your friend on this one bro
Take the coil pack rails off and use a 3" extension and ratchet should be all you need along with anti seize for the spark plug threads and some dielectric grease for the wire boots. if its you first time just take your time and dont get frustrated number 8 isnt that bad...sometimes i use the plug socket and extension to find the plug before snaping the ratchet into place. After you do it once its a 20 min job.. good luck.....oh and a beer or to always helps with just about anything.
some times you can get to the back one's easier being underneath the car and coming up also, but it is a pain in the *** wrench throwing is alrite (JUST NOT AT THE CAR PLEASE) and if you havn't got spark plugs i would definately recommend NGK Iridium dont remember the part number but get the ones with a .60 gap have fun though i dread it everytime i do it
be sure to take off the coil pack rails! makes it a hundred times easier! the rear passenger side plug is a pain in the butt and much easier from under the car. you don't have to do these one at a time, because it is impossible to get the wires crossed. also, all the wires are the same length and can go on any cylinder. also, put a SMALL amount of dielectric grease or silicon spray around the inside of the plug boot to help it slide on easier. i take out all my plugs every weekend to check the gap and condition, so i have some experience in this department. lol
p.s. it is normal to yell, scream, cus, and throw tools during a spark plug change on a camaro/trans am, so try to be far away from friends, family, and small children during this process. lol
good luck
good luck
hey whats up? quick update on changing the plugs and wires on my car. was able to do the drivers side ones with ease. but now im stuck on the passenger side cant take the damn boot off wich way do u turn it. getting real fustrated here. i also took of the coil racks for a little space which helps a little. any help or tips will be good .
Just pull it straight off. Sometimes there's so little room in there you can't get a firm enough grip with your fingers on the boot to pull it off. Its just part of this shitty design for an engine compartment. Sometimes you just have to pull it at the wire, but it could break and you'll have to buy a new wire set for $36.00. If the clip stays on the spark plug, you can still get the socket on it to get it out, just in case your's does brwak while trying to yank that sumbitch off.
update again, finished installing the plugs and wires that was a @#$%^ took me the whole day from 11:00am to 9:00pm my hands are killing me. that was my first time, but already know what tools to use for next time. hopefully it wont take me a whole day, maybe half day? anyways want to thank all yall the helped me out with some tips. couldnt done it with out yall. thanks again and ill be in touch peac.
I don't know. I was doing my gaps for my 427ci for the past 7 years at .045. I changed my plugs a couple months ago and I tried them at .052.
Absolutely, 100%...zero change in the way the engine performs throughout the rpm range.
Gaps don't matter until you start getting into big horsepower, nitrous or forced indusction.
But I think GM changed the original gaps for stock engines from .060 to .055.
So I went somewhere inbetween and went with .052. Same ****, its all the same.
.060 was the original spec for our cars(platinum)
if you are going to change your stockers they are now iridium which calls for a .040 spec. ill look for the bulletin #
Bulletin No.: 03-06-04-060B
Date: July 30 2008
Subject:
Information on New Spark Plugs and Gapping
Attention: Please disregard the Set Gap Per Vehicle Specification statement on the side of an ACOelco(R) Iridium Spark Plug Box. The statement will be removed from the boxes in the future.
Supercede:
This bulletin is being revised to add the Chevrolet SSR and the 2005 Pontiac GTO. Please discard Corporate Bulletin Number 03-06-04-060A (Section 06 - Engine/Propulsion System).
^ A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design the gap of the spark plug has also changed.
^ The new spark plug P/N 12571164 with AC Delco P/N 41-985 is gapped to 1.01 mm (0.040 in) when the spark plug is made.
Notice: The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
Try a 3-4" piece of rubber hose over the end of the spark plug when installing new plugs. Makes for a handy temporary extension...
I also use a Craftsman spark plug socket without the rachet on # 8. The socket has a 3/4" head you can get a wrench on to make small little turns to aid in final tightening of that hard to reach bastard...
Any change to gas mileage?
INFORMATION
Date: July 30 2008
Subject:
Supercede:
Date: July 30 2008
Subject:
Supercede:
.040 is too small for an LS1, any LS1.
.050 - .055 is best
