dash lights
Old 05-17-2009, 08:05 PM
onebadredz28's Avatar
Default dash lights
hey i have a 95 z28 and i blew a 5 fuse for the dash lights dimmer switch. I put a new one in and they keep blowing on me. They worked before i out it away for the winter. I did however put a new pass window motor in and did not connect the little bulb to light up the pass window switch could that be it? thanks
Old 05-18-2009, 07:14 AM
Mike in LA's Avatar
I would go back and check to make sure that none of the wires are exposed from the window motor and connect the light bulb. Also check the wires around the dimmer switch, popping fuses gets very frustrating.
