Burning oil?
Old 06-03-2009, 06:39 PM
RedDemonLsX's Avatar
Default Burning oil?
I seem to be losing about 1 quart of oil between changes (3k miles),the car has 40k miles using Mobil 1 5w30 with mods in sig..I dont have any leaks i can find and any help would be greatly appreciated..
Old 06-03-2009, 07:08 PM
LS6427's Avatar
Thats not horrible, but still a little much for 40,000 miles. Try 40 weight oil or even 50. It should definitely decrease unless you have a ring(s) issue. Catch Can will also help a tiny bit, but not much.
Old 06-03-2009, 10:12 PM
Save the manuals!
wssix99's Avatar
Specs say this is OK if you are under 58K miles. Guidance is 1 qt over 2K miles. Here's the latest TSB from the General: http://www.pistonslap.com/tsb/010601011A.pdf
Old 06-03-2009, 11:55 PM
killagt's Avatar
try using maxlife 10w30 ( red jug from walmart ).
Old 06-04-2009, 01:04 PM
01formula6's Avatar
Considering how thin the Mobil 1 is that you are using, I'd say only losing 1qt is actually good. Try a thicker 30 weight oil or even a 40 and I bet your consumption gets cut in half. My car seems to like Castrol Syntec 5W-40 the best.
Old 06-04-2009, 03:02 PM
Mr Incredible's Avatar
M1 does lose a little more volitiles than some other oils, but as a 30w it's about midpack. Not really thin for a 30w. You could try just about any other 30w and see if consumption goes down. 1/2 qt per 3k miles seems normal-ish for most oils/most cars.
Check your PVC lately?
Old 06-04-2009, 03:04 PM
91RS383's Avatar
I wouldn't worry either. With 40K miles it's not like your buying oil every week.
If you're making plenty of oil pressure 10PSI per 1K RPM leave it alone.
