Which fuse/relay controls the interior dome/rearview mirror lights?
Old 06-10-2009, 09:28 PM
Shackleford's Avatar
Default Which fuse/relay controls the interior dome/rearview mirror lights?
The lights don't come on anymore.
Old 06-10-2009, 09:59 PM
Hamrdown's Avatar
The manual doesn't list those. I would just pull a fuse at a time and look to see if the metal filliment running in the middle if the fuse is broken or cracked. Use a flashlight for best results. I would check the courtesy fuse 1st. On the main fuse block under the hood. But your lights may just be out as well.
Old 06-10-2009, 10:12 PM
02BLACKTAWS6's Avatar
You may be able to save yourself some time by checking the fuse's continuity with a multimeter.
Old 06-10-2009, 10:29 PM
I checked the fuses once and didn't see anything, but I'll look again tomorrow. I've thought about replacing the bulbs, but none of the interior lights work.
Old 06-10-2009, 10:33 PM
02 35thLE's Avatar
should be the courtesy fuse but the bcm controls the lights.
Old 06-11-2009, 10:19 AM
bcm??
Old 06-11-2009, 05:07 PM
02 35thLE's Avatar
Originally Posted by Shackleford
bcm??
Body control module
Old 06-11-2009, 05:32 PM
Body control module
I didn't find in bad fuses in the dash. What else does the BCM control?
Old 06-20-2009, 12:27 PM
Any more help?
Quick Reply: Which fuse/relay controls the interior dome/rearview mirror lights?
