t-top squeek from center ?
Anyone else get this ? Getting a squeek right above the rear view mirror. T-tops can be in or out and it keeps squeeking. Anything i can do ?
someone on here mentioned a while back you could slightly bend the tabs the pins slide into for a more snug fit. You also might want to try silicone on your t-top seals. not armor all, straight silicone. Sub frame connectors are also supposed to help with this. Mine just started doing the same thing the other day, ill keep you posted as to my results.
yea i might take out the headiner to see. Just want to see if anyone knew exactly what it is. In the first part of your post are you talking about the center bar ?
