Drivers Side Window Alignment, off the track?
Old 06-29-2009, 12:03 PM
AgentLS1Z's Avatar
Default Drivers Side Window Alignment, off the track?
I just tried to adjust my drivers side window. I adjusted some of the tracks which made it somewhat better but it seems like something is broken. I can wiggle the window and I can slide it back and forth with ease. Should'nt the window stay stationary? When I start to roll it up it begins to fall inward and rubs against the rubber triangle and gets stuck, then I have to guide the window up. Anyone know of this issue?
Old 06-29-2009, 12:34 PM
99T/A_Marine's Avatar
My car does the exact same thing. Ever since the day I bought it. I'm not too worried about it though since it doesn't leak when it rains. But it is an eyesore. Hopefully someone will chime in and help us both out dude.
Old 06-30-2009, 10:03 AM
Save the manuals!
wssix99's Avatar
Check the two threads below to see if you have the common problem with a broken rear guide:
https://ls1tech.com/forums/general-ma...w-related.html
https://ls1tech.com/forums/general-ma...l#post10342759
