AC Compressor leaking from case?
Anyone seen an AC compressor leak from the case?
I have leak detector in the system, Compressor does not cycle on at all, and is leaking from what looks to be the case.
The lines from the compressor are bone dry with no traces of leak.
The system holds 90-95 psi of pressure so it's holding...
So you think the compressor is bad?
Are you sure it was from over tightening? I had a couple compressors leak on me and I realized it was because my bracket is slightly warped. Has this happened to anyone else? I'm guessing it is warped from the heat...
