Fuel pressure problem. need help!!
my z28 has been hesitating and wont start the first 1-2 tries depending on how long it sits but it will always start on the 3rd. so i did a fuel pressure test and at idle it had 36psi and when revving it went up to 42-43psi. i know thats not what psi it should be. so my main question is what psi should it be running at? also im pretty sure that means i need a new fuel pump??
please helpp
please helpp
LT1 is different, maybe you can find the answer here: http://shbox.com/1/4th_gen_tech2.htm...essure_testing
