Rear main seal?
Old 08-16-2009, 05:22 PM
TheSecretFormula's Avatar
Default Rear main seal?
Hey guys I am doing a clutch swap and my tranny is out at the moment I figures why not replace the RMS being that the car has 145,000 miles. I do have a very small oil leak already which could be the seal or the pan gasket. I know the seal pops right out, but do you need the special tool to install the new one or can you do it without?
Old 08-16-2009, 07:30 PM
fleetmgr's Avatar
You can do it without, just be gentle. Also check the oil gallery plugs at the back of the cam, they can leak too.
Old 08-16-2009, 07:45 PM
I am actually almost positive the seal isn't leaking at all. I believe the small oil leak I have is from the pan. I just went under the car a little while ago and with the car sitting on an incline with the front higher than the rear all day the seal is bone dry. Would I be better off just leaving well enough alone? Oil gallery plugs seem dry as well.
Old 08-17-2009, 04:42 AM
99RTA's Avatar
There is a plug in the back of the crankshaft too that can leak.
