I cant open my hood
prolly bad shocks under hood, so it aint gettin pushed up from release, or it is gettin caught some how cuz my older Trans Am,89, has that problem, an i had to hit the top of it ALOT an pretty hard for it t open
ya just hand, but not sure an dont want u to dent ure hood, my 89 has only 3 dents in it XD 2 on the hood an 1 on the side, but its been driven into a ditch lol, give it like 3-4 hits on the front of it near where the latch is after u pop it, make sure the first latch is unlocked just not popin the hood, if u have a friend, it could b just bad shock, could pop an have friend try to pull up if u have enough lip
also can put ure hand over the spot an just hit ure hand to cushion the blow, cuz i am guessin u dont wanna leave an accidental dent, but once u get it up, check the shocks cuz constantly doin that WILL dent it, took a couple months to put the 2 dents in my tranny
hey, once you get it open, put new shocks on it, then check it again. when open you should be able to adjust/tighten your latch. if it still doesnt work, check the rubber things on the body, they position the hood vertically for opening/closing and visual stuff. just a thought :-) my 2 cents lol
