Ok ,what the heel, please come inside.
Im working on a 1999 Pontiac Trans Am with less then 30 miles on the car. Its got a ford 9", and BMR rear suspension. The problem Im having is a rattle when you hit bumps driving down the road. Its coming from the right rear, and sounds like somethings about to come loose. Ive jacked the car up and cant see anything loose, but driving down the road, and somethings gonna fall apart. Any ideas..
Thanks
Charlie
Thanks
Charlie
I had a really bad noise from the right rear when I would hit little bumps in the road as it turns up my spring was rubbing the panhard bar bolt However I think this is a product of being rear ended at one point...
hmmm maybe shock/spring bushings. sometimes if you dont seat the rubber spring gasket right when you set the spring in, it will cause a rattle like crazy. easy to see if you look hardenough....you shouldnt really see the gasket much at all, so look and see if you see a chunk of it hangin out.
Ok update time. I ripped EVERYTHING out from my rear compartments, and didnt even get out of the driveway before I heard the clank / rattle / loose sound... Man something is about to give, Ive got literally $18,000 in mods in this car. I stuck my head out the window while a buddy was driving. Its coming from the wheel. But these arent multi piece wheels.
PROBLEM FIXED. Ok, try and follow me here, hard to explain. So, I've had a little chirp chirp chirp noise coming from the right rear (along with the above mentioned sounds) for a while now. I got fed up and jacked the car up to check and see if the little wear indicater on the rear brakes were chirping. NOPE, the pads had an easy 80% life left. I threw my hands up, not knowing what to do then, and grabbed the whole rotor brake assembly to shake it to death. I was pissed. And noticed, THE ENTIRE DAMN ASSEMBLY was moving. The rotor, callipor and the bracket that everything bolts to that bolts to the ford 9" axle tube. I was like what the hell. I looked and the four nuts and bolts that bolts the bracket to the axle tube was damn loose. I freaked. I tightened it all up and buttoned the car back up and went for a ride. AAAAWWWWWHHHH nice and quiet. All you hear is that sweet turbo spooling up. So, Im good now. But thank all of you for your help. I love LS1 Tech. Now, If The Corvette Forum could do the same.. HaHa....
