Dieseling after MCCC
Did anyone else have a problem with the car dieseling after using Mopar Combustion Chamber Cleaner?
I followed all the steps in one of the forums and I had to choke out my engine to get it to shut off.
Ok I figured out what I did wrong......... I was supposed to turn the car off before I used all of the MCCC. I did the opposite. It started dieseling after turned off the car. I should have turned it off and then used the last bit of MCCC to stall it out. I am pretty sure thats how it works.
If you have a tiny bit left in the can you can just spray it into the vaccum port right after you shut it off and walk away from it.
