p1530
p1530
Threw codes p0154,p0161 for passenger side 02s replaced both fronts & codes have just come back & threw p1530 throttle actuator curcuit, all at the same time.
Couldn't find any info on here or gear chatter, as to the cause & solution to the last one, any help appreciated.
what codes is that? are the o2 reading heater cuircuit? is it reading lean? is it reading rich? what does the code say... It doesnt just say "02 sensor" there is a ton of different 02 codes and VERY RARELY does an 02 sensor go bad... thats a thing of the past, unless they are replaced with aftermarket junker 02 sensors...
Pretty sure unless I wrote it down wrong. definitely started P1
Think I may have screwed up when typing it into my phone I'll check later to see if it should have been p1153.
I was typing it from the passenger side off the gauge pod because the g/f was driving.
I see... unplug the 02 sensor and check that you are getting power to the 02 sensor... make sure it is connected all the way. then at worst case, there was a thread about rtv silicone possibly getting on the sensor from the header gaskets...
