Tunnel Brace Mounted Torque Arm
Old 10-06-2009, 11:44 AM
WhiteHawk489's Avatar
Default Tunnel Brace Mounted Torque Arm
Just ordered a UMI Tunnel Brace Mounted Torque Arm from WS6Store to replace the stocker that broke.
http://www.ws6project.com/user_stor/...oducts_id=1261
Is there anything to worry about as far as install goes? It looks straight forward. I also ordered the hardware kit to replace the bolts at the rear. Also its ajustable so i was wondering if anyone had any advice on initial setup. Thanks!
Old 10-06-2009, 12:41 PM
DropTopBird's Avatar
Install is pretty straight forward. An impact gun really helps on getting the bolts old bolts out. There is a writeup on setting the pinion angle on here, but it should come preset at a good range if you want to drive it somewhere to get adjusted.
Old 11-20-2009, 09:22 AM
got it in no prb just beware that even though it says it works with a stock exhaust, which it does, the y pipe sat right on the tunnel brace causing a nasty vibration and noise under load. i just loosened the exhaust everywhere i could and tweaked on it til i got barely enough clearance.
