Sponsored by: CARiD
Is this the correct part for headlight?
Old Nov 14, 2009 | 04:50 PM
stockerws6's Avatar
Default Is this the correct part for headlight?
From gmpartsdirect:
Description Year MSRP Price Your Price
Low beam Left - 1998-02 - $166.10 $103.65
My drivers side headlight just went out and I think I know how to replace it but wanted to be sure it is the right part. I couldn't find the part # on their site. I attached an image also. It is number 7 in the image. That's all I need, right?
Thanks.
Old Nov 14, 2009 | 06:48 PM
Danny2tek's Avatar
what the bulb blew is what your saying? $100 bulb WTF?
Old Nov 14, 2009 | 07:11 PM
stockerws6's Avatar
Can you just replace the bulb in the headlight?
I see on the back where the wire connector pulls off the whole unit but does it also twist or something to pull the bulb out?
Old Nov 14, 2009 | 07:23 PM
muteki's Avatar
I am not sure where you are getting your lights, but mine cost like $8-$20 each depending where I buy them. When you remove the plastic shroud off the front of the headlight area, there is a retaining frame around the bulb. Remove the entire glass bulb, throw it away and replace.
Old Nov 14, 2009 | 07:26 PM
stockerws6's Avatar
Thanks. I guess I am looking at the wrong part.
Just to clarify. You guys are saying that the whole square glass piece needs to get replaced and that it shouldn't be more than around $20?
Old Nov 14, 2009 | 07:31 PM
muteki's Avatar
yep, you are correct. It should look like Part #9 on your diagram
Old Nov 14, 2009 | 07:36 PM
stockerws6's Avatar
Thanks very much for the help.
The funny thing is that I have owned the car since new and I don't ever recall changing the headlights. I've changed the DRL's plenty times and that was simple.
I just noticed the light was out and I didn't really take a close look. I assume the plastic frame in front is connected by just a few screws that are easy to remove.
Old Nov 14, 2009 | 07:45 PM
muteki's Avatar
Correct again. I have only changed mine one on this bird, a couple times on my last one. You might just want to pull off the back plug and plug it back in, sometimes just a loose connection will turn it off. My driver's side blinks off about once a month and comes back on before I get home....makes me mad, because I always forget about it until it happens again...lol
Old Nov 14, 2009 | 07:48 PM
stockerws6's Avatar
I will try re-connecting the plug first. Thanks for the advice!
Old Nov 15, 2009 | 08:40 PM
wssix99's Avatar
Save the manuals!
BTW - If you change the light, be sure to turn the correct screws! There are four screws that hold a metal frame on the bulb - one in each corner.
Don't turn the screws in the middle of the top of the unit or in the middle of the side. These are for aligning the bulbs - and you don't want to go there. (Its a horrible design.)
Old Nov 17, 2009 | 05:14 PM
muteki's Avatar
Any luck with the repair?
Old Nov 20, 2009 | 09:30 AM
stockerws6's Avatar
Everything went fine. I picked up the headlight at Autozone for 12 bucks. It was pretty simple and no I didn't touch the alignment screws.
Thanks again everyone!
