Hatchback door strut mounting post broken:
Old 10-10-2009, 05:10 PM
sabre_805's Avatar
Default Hatchback door strut mounting post broken:
2000 WS6 has broken read hatchback strut mounting post.
It's a plate with a pin that the strut attatches to.
It is fastened to the inside trim panel by glue or something from factory.
I have thought about jb weld, 24 hour epoxy and small bolts.
Does anyone know what kind of glue or material I should use to repair it?
Thank you.
Old 10-11-2009, 12:19 AM
WhiteRhino's Avatar
Mine did the same thing. I already had the hatch trim piece off. I notched a piece of the hatch out. I made the notch just big enough to fit a wrench in. I think it's a 15mm for the strut ball mount on the inside of the hatch. Then I just tightened the ball assembly up. Once you put the trim on you can not till it's been cut. It's been fine for years.
Old 10-11-2009, 12:44 AM
sabre_805's Avatar
It's the plate that the post screws into not the post itself.
Broken loose from trim panel.
Old 10-11-2009, 09:16 PM
WhiteRhino's Avatar
I'm talking about the plate as well. Once you notch out the hatch, you can slip an open ended wrench onto it. Then tighten the post and it shouldn't have any play in it.
Old 10-12-2009, 12:07 AM
sabre_805's Avatar
We took it apart today and notched out a section.
The metal piece that the post screws into was loose and rattling around.
After going round and round the only way was to secure it with sheet metal screws.
If it holds it should work fine and the gray trim panel hides them.
I have a pic of the other side as well to show what we did.
Old 10-12-2009, 10:10 PM
WhiteRhino's Avatar
I see now. On mine, the nut just broke of the plate. My plate didn't actually break loose. Glad you got it fixed!
Old 10-13-2009, 05:08 PM
sabre_805's Avatar
Yep I figured the pics would explain it.
My first car was a 98 WS6, stolen in 2006.
Keep it.
Quick Reply: Hatchback door strut mounting post broken:
