yellow goo in throttle body coming through tube to valve cover?
Probably from moisture buildup mixing with the oil makes that yellow goop ****. May have a leak in your PCV valve allowing moisture in or if you have been making alot of short trips it tends to build up. Does your Oil cap have the same crap on it?
Thats a pretty short trip, you need the motor to get to full temp for a while to evap all the water out of the motor. Really time is a better gauge for that, just do the carb cleaner trick to check for any VAC leaks in the PCV. If you get nothing then I wouldn't be too worried unless it was a excessive amount of buildup
I'd get a new PCV valve and see if that helps. Might want to get an air compressor and blow all the PCV lines out.
