All of a sudden burning MORE OIL than usual! Whats going on?
All of a sudden I am burning more oil than usual! I burned one half of a quart in 2200 miles! Has me a little stumped. Not burning oil by looking at the pipes. No oil found on the throttle side of the pcv. Dropped the oil and went on a road trip with steady throttle (nothing over 3k rpm). Same oil consumption. Pulled one of the AC delco plug with only 7k miles on them and just found the ceramic to be a reddish color (no oil or heavy carbon deposits). One mechanic said sometimes oil gets splashed up in the baffles of the valve cover and gets sucked into the pvc system. He told me to run a bead of RTV gasget maker on the baffles to prevent this. Have not done this yet.
What do you guys think?
This car made about 12 runs at the track as far as I know after 60k miles on it. Lots of highway miles and some FUN miles also.
I have owned the car since 93K miles and put 10W30 Mobil 1 in, and I was told that it has had Mobil 1 since the factory (not sure of what weights were used before I owned it).
02 T/A WS6, M6, dyno tuned, LS1, EGR delete, no cats, SLP LM2, SLP Headers, SLP Lid, 113k miles,
you good, man. I dynoed mine the other day which was less than a week after an oil change and after dyno runs I had to put in like almost a qrt. That was after some spirited runs as well.
I think hard driving does it.
Thanks guys for the re-assurance. I just though it was strange to start burning oil that quickly. Has anyone heard of the RTV trick inside the valve cover baffles? That was a suggestion from a previous GM mechanic.
if you check your car when hot it is going to read alot lower.(at least on mine) I realized this when I saw it was low, so I added half a quart after only 1000 miles... I checked it in the morning cold, and I was almost a half a quart over. I beleive there is a windage tray in the oil pan that will hold oil for a while... it takes mine a couple hours for all the oil to reach the bottom to get an acurate reading on the dipstick.
What is the best way to check that? I pulled the hose off the throttle side while the motor was running and it started to idle rough. I put my finger over the hose and it idled smooth. Some people say the pcv is bad if you find oil on the throttle side, and that side4 was dry.
if you pull the pcv valve itself out of the tube and shake it, it should rattle if its not clogged. no rattle, its clogged.
id also suggest investing in a catch can to stop the oil flowing into your intake manifold.
PCV valve might be bad.
You just had a valve seal fail or maybe a few of them.
Maybe a ring issue.
Do you make a smoke trail when you stomp the gas pedal from a roll, say from a 50 mph roll?
RTV....ridiculous recommendation, especially from a GM mechanic.
