a.c. line removal
Old 10-18-2009, 12:42 PM
maxgee's Avatar
Default a.c. line removal
i have to replace my main a.c. line, it travels from compressor to dehydrator to condenser.
i removed the bolts that hold it in place, but proving difficult to remove it from the behind the compressor to snake it out. what are you guys doing to remove this a.c. line?
Old 10-18-2009, 09:18 PM
maxgee's Avatar
help?
Old 10-18-2009, 11:17 PM
LS6427's Avatar
Cut that sucker up with a razor knife to make it easier to get out. Also, cut the metal lines with hand cutters.
Just curious....where's the leak?
Old 10-18-2009, 11:24 PM
whytryz28's Avatar
Short of removing the ac compressor which isn't that hard, you can hack it up.
Old 10-18-2009, 11:35 PM
LS6427's Avatar
Mine got a little pinhole leak like 6 months ago in the rubber, but it was so close to the factory crimp in the metal line...I was able to cut an inch out of the rubber to get rid of the pinhole, then I reclamped it onto the metal line. Been holding great since.
Old 10-19-2009, 06:36 AM
maxgee's Avatar
I thought about hacking it up, but if I cut it out I'll still have to figure out how to install the new one.
I guess the compressor needs to come out as it's what's hold me back from getting the line out.
The problem I remember a friend who tried replacing his compressor and he was unable to get it out without extensive work to make space so the compressor could be removed.
Old 10-19-2009, 09:27 AM
slow's Avatar
the compressor wasn't that hard to remove once you have that line disconnected.
I'd just pull it out, from the bottom.
Ryan
Old 10-19-2009, 12:37 PM
LS6427's Avatar
Where is that line leaking?
