I'm just starting to have BCM problems questions.
Old 11-11-2009, 08:43 AM
onebadazzls1ta's Avatar
Default I'm just starting to have BCM problems questions.
I've done the vats bypass does that mean I have to worry about the vin and such when I order a new one from ebay? will the resistance be different with a different BCM?
Old 11-12-2009, 07:40 AM
samson_420's Avatar
Yes, completely. . . . .Your BCM holds the VATS specifics and the Key FOB programming.
I have a BCM I got from eBay which I still have not used. Since I will have to determine the resistance value to bypass the VATS.
Old 11-12-2009, 08:39 AM
So the resistance will change with a different bcm? Like I said I've already done the vats bypass according to the resistance on the key now....
