yellow goop in throttle body vaccum port and oil cap
Old 12-12-2009, 01:33 AM
blk99sleekbeak's Avatar
Default yellow goop in throttle body vaccum port and oil cap
Since i put a catch can on my car due to a broke pcv line i get a yellow goo in my throtle body and just noticed it under my oil cap the other day.the system is hooked up right.i used a diagram that i found on here.there is never any water in my oil when i change it.i suppose this is stuff making it past the catch can.any way to stop this?
Old 12-12-2009, 04:12 AM
myk
myk's Avatar
I'm pretty sure that finding that goop on the cap is normal; not sure about the throttle body though...
Old 12-12-2009, 09:19 AM
it never did it in either place until i put the catch can on it
Old 12-12-2009, 11:31 AM
ULTIMATEORANGESS's Avatar
i found that crap in my oil cap too.
Old 12-12-2009, 11:40 AM
Choppers's Avatar
i have it in mine and mine is not a ls1
Old 12-12-2009, 12:32 PM
Scira's Avatar
Yellow under the oil cap means moisture in the oil. Make a lot of short trips? If you make a lot of short runs and the oil doesn't get hot enough to burn the excess water, thats what happens.
As far as the TB.......WTF? No clue.
Old 12-12-2009, 06:54 PM
xXSilencerXx's Avatar
I've had it once in my cap, I was like told Scira said it was from short trips and not allowing the oil to get hot enough to get rid of the moisture.
Old 12-12-2009, 08:03 PM
Sharpe's Avatar
You're just now noticing it or you just now started making short trips, or it is weather related. It's normal.
Old 12-13-2009, 04:02 PM
Im just now noticig it.i dont make any short trips in it.i usually only drive it on the weekends.im pretty sure it never did this until i put the catch can set up on it.
Old 12-14-2009, 01:45 AM
GoodOlBoy0404's Avatar
It's in my 98 Ls1's cap as well... I thought something was wrong but apparently its normal for short trip cars, that's what the shop said.
