Either I have something clogging my oil filter or I'm in serious trouble
Old 01-30-2010, 05:38 PM
onebadazzls1ta's Avatar
Default Either I have something clogging my oil filter or I'm in serious trouble
My oil psi is at 20 at idle and 40 at speed, Think it could be a piece of sludge or is my oil pump on it's way out? I need suggestions to go with on a new oil pump.
Old 01-30-2010, 06:26 PM
slayerized6's Avatar
i experienced the same problem recently and just fixed it yesterday. read my posts for the past few days and youll see what im talking about.
it turns out it was my OPSU (oil pressure sending unit).
cliff notes
-I had replaced the OPSU 9 months ago when i did my IM swap
-Late December- oil pressure would be at 20-25psi at warm idle
-changed oil and filter twice in one week. nothing changed
-ran seafoam in the crankcase thinking i built up sludge around the pickup tube. nothing changed
-changed the oil pump, thinking the pressure relief valve was screwed up. nothing changed (psi did increase a little because i swapped to a ported ls6 pump)
-exhausted all options. the only other problems that could have caused a low psi was a faulty OPSU (even though i changed it 9 months prior) or my lower assembly was shot to ****
-changed the OPSU in 15* weather. Oil pressure reading was back where it should be. problem solved
Old 01-30-2010, 06:28 PM
fleetmgr's Avatar
There's nothing wrong with 20/40.
Old 01-30-2010, 06:29 PM
btw, what the year/make/model of your car?
change your oil and filter and see if that does anything. if not, change the OPSU and see if thats the problem.
Old 01-30-2010, 06:33 PM
LS6427's Avatar
Your pressure is fine.
Old 01-30-2010, 07:11 PM
99 bird
Old 01-31-2010, 01:25 AM
whytryz28's Avatar
Mine is like 15psi at idle and around 55-60 cold running and 40-50 hot running.
Old 01-31-2010, 01:50 PM
01WS6er's Avatar
i have seen on several truck that the pickup o-ring has deteriated and is causing the oil pump to pick up air. dont knwo if teh cars are teh same way, but i would think they are. you are looking in about 40 bucks in parts form the dealer. o-ring and pan gasket.
Old 01-31-2010, 01:58 PM
do the smart thing a replace the OPSU first.
I had the same problem a few weeks ago. Oil pressure was reading low and i went all out and did a Thunder racing oil pump. After intstall, i still had low pressure. Changed the OPSU and problem solved
Old 01-31-2010, 02:03 PM
travismcgillsdaddy's Avatar
my oil press was low and it was opsu, so i changed it and fixed it, another time it was low on pressure is cause it was low on oil. it fixed my problem both times
