changin oil pan gasket and rear mail seal
To do the oil pan gasket you need to lift the motor up so the pan will clear. The rear main seal pull the trans and the clutch flywheel or flex plate depending on what trans you have then pry out the old one with a flat screw driver and gently tap in the new one
