Yes, Another Rear Main Seal Thread
I got tired of searching and finding different answers, so please bare with me.
My new seal came in the mail today, the "revised" version. Do I need to buy a new backing plate?
And should the seal be lubed before installing?
I've been reading answers that swing both ways, so please post up if you are 100% sure. Thanks!
well here it is, direct from the GM SI
* Do not lubricate the oil seal inside diameter (ID) or the crankshaft surface.
* Do not use the crankshaft rear oil seal again.
# Lubricate the outside diameter (OD) of the oil seal (1) with clean engine oil.
# DO NOT allow oil or other lubricants to contact the seal surface. Lubricate the rear cover oil seal bore with clean engine oil.
DO NOT allow oil or other lubricants to contact the crankshaft surface.
