Help me KILL my low oil light.
Old 04-22-2010, 01:10 AM
vivenvex's Avatar
Default Help me KILL my low oil light.
OK the story thus far..
Light came on added 2 qts even tho my stick read full...
Nothing...
Changed the sensor...
Nothing...
Did an Oil change...
Nothing...
My pressure is fine. 42 at idle and at temp.
I hate that damn light! I dont wanna deal with wire maint tbh. Anyone know of a way to get rid of the damn thing? Car runs perfect, smooth, powerful. I just cant get rid of the light.
If there isnt anything left but wireing im pulling the bulb...
</3
Old 04-22-2010, 01:26 AM
98pontiac's Avatar
are you sure you changed the right sensor? I doubt it is run through a fuse, but it wouldnt hurt to check them all. otherwise you have a broken wire. it shouldnt be that hard to find...
Old 04-23-2010, 07:31 AM
FrankSS's Avatar
the sensor is a PITA to get to in the side of the oil pan.... you would know if you changed it b/c you would have had to drain some oil or had a mess all over. if you did replace that one, then you have a wiring issue. you can try to jumper the 2 contacts together and see if that gets rid of your light. or if you can find a crimp splice and where the wires run into the engine compartment, splice them together that way. and the light is an SM LED, so good luck pulling it
