Ignition problems killing me. Help please.
Ok. I got the correct LS1 pedals yesterday for my T56 swap. Everything was fine when I started. I had LT1 pedals in it. Clutch was not disengaging so I swapped in the LS1 pedals. No problems there. In order to put them in I decided it was best to pull the steering column. No problem because I've done it before. Well, on the blue ignition switch connector, two wires were pulling out. When I put everything back together with those two wires in the place I thought they went, NO START. Security light was flashing. So I pulled everything back down and swapped those two wires. Now the car starts but won't shut off. The two wires I'm referring to are a pink and brown wire. The yellow and red wires are still connected with no problems. WTF is going on? If brown wire is in the top where I believe it should go, car cuts on and off like it should but no start. If I put the pink wire in the top, car starts but you can take the key out and it will remain started. PLEASE for the love of whoever you hold dear, HELP ME!!!! I just spent 2500 dollars on a T56 swap I can't enjoy.
Anyone else? If someone has a picture of their steering column removed or even better a picture of the blue connector plugged into the ignition switch it would be very helpful.
