Blinkers Not Working
Old 07-07-2010, 11:34 AM
bigbirddriver94's Avatar
Default Blinkers Not Working
When I try to use my blinkers the controls feel fine and move up and down, but no green arrow comes on the dash and no exterior lights come on. I checked all of the fuses and dont really know where to go from that. Check for power on the lights? Could it be the lever itself? Just need some ideas as to finding the source of the problem.
btw its a 94 Trans Am A4
the battery had been disconnected and the reinstalled the day i noticed this
Old 07-07-2010, 12:25 PM
mrchyzy16's Avatar
check your blinker fluid...
Old 07-07-2010, 01:10 PM
BOA279's Avatar
thats funny because I just took mine out of the garage and my green arrow on the dash is on solid in either direction...no blinking though
Old 07-07-2010, 04:17 PM
I8ASaleen's Avatar
There is a small module that is most likely broken. It is a little electrical piece that is near the bottom of the steering column, it goes out frequently.
Old 07-08-2010, 07:31 AM
87gnx's Avatar
there is a gazillion posts on this. search "turn signal relay". as stated above its a simple fix, part should be around ten bux.
