help
Old 08-03-2010, 04:33 PM
bigpphil61's Avatar
Default help
i have a 2000 pontiac firebird formula with 115k that wont run without me holding the throttle down when i first start it up after sitting for awhile but when it warms up it runs perfect. i had a ford f150 that done the same thing and i've had a few customers with the same problem and i replaced the idle air control motor on the vehicles. i was wondering if this could be the problem with it to. the amp gauge is reading 10 until i rev it up.
Old 08-03-2010, 06:56 PM
SOMbitch's Avatar
You can usually clean it and not have to replace it if it is acting up......
Old 08-04-2010, 04:14 PM
bigpphil61's Avatar
K I'll try that then if it keeps acting up I'll replace it
Old 08-11-2010, 11:40 PM
bigpphil61's Avatar
i found the problem my car every time i went to start it the motor would turn over once so i tightened the battery cables and now it runs perfect
