AC problem, need help guys. Thanks
Old 08-24-2010, 04:40 PM
whytryz28's Avatar
Default AC problem, need help guys. Thanks
My friends a/c has been acting up recently.
It blows cold air at idle but once you drive it/ give it gas the compressor shuts off I guess and it blows warm air.
Hooked a gauge up and its around 45psi at idle then when you give it gas it drops to around 30psi, then I hear a click (guessing the compressor shutting off) and thats the end of it.
Is it low on freon?
Old 08-24-2010, 08:42 PM
fleetmgr's Avatar
Probably, and if so it has a leak that needs fixing.
Old 08-25-2010, 04:19 PM
whytryz28's Avatar
Ok, we started it up and it does the same thing, cold at idle, shuts off while driving. Must be a super slow leak then. Ill shove some freon in it and see what it does. Its still good on the gauge so its not over filled.
Old 08-26-2010, 01:26 AM
chrysler kid's Avatar
sounds like you are low on freon. the ac pressure switch sounds like it is kicking off the compressor because of low pressure
they sell freon in a can with a pressure gauge, get the one that has a gauge with a trigger on it. the ones that are just a gauge on the line are garbage
