gas tank removal
gas tank removal
to those that have done this. how hard is it? is there a write up somewhere besides a Haynes manual?
this will be on a 1998 Z28
why do you want to remove the tank? not very hard at all. just remove screws at the neck and bolts to the straps. alot of people opt to cutting the gas tank door to gain access to the pump w/o having to cut or remove exhaust
Ive done the trap door and pulled tanks but ive never put a tank back in lol
Trap door is easy, just be careful how deep you cut with the cut off wheel, be really careful not to bend the fuel level sender arm pulling it out, and use silicone to seal off the plate when you put it back on.
^^^thats what i used. i was just careful and barely cut into the metal just to make sure i didnt cut anything i was suppose to. pretty easy w a dremel. cuts smoothly and very quickly. i had mine cut in a matter of minutes
Man those sparks stung...
