Wipers
Location: Just because the voices aren't real, doesn't mean they're not right!
Most cars nowadays have a separate washer pump installed directly either in, or immediately next to, the side of the washer tank and it will have it's own power supply connector. Usually two wires. Also look for a small diameter rubber hose. It's usually attached directly to the outlet nozzle of the pump and leads off to the right/left nozzles that spray the windshield.
Maybe the plug came unplugged or it may be that you just have a bad pump. A washer pump is usually fairly cheap to replace.
HTH
HTH
