Need some help with coolant leak, anyone?
Old 05-03-2011, 02:56 PM
johnzss's Avatar
Default Need some help with coolant leak, anyone?
Finally got a chance to take the car out for a spin. After an hour or so and reaching to operating temp, My car has been leaking coolant from the resovior cap. The only thing i can think of is the t-stat not openeing up? Any suggestions?
Old 05-04-2011, 10:18 AM
Save the manuals!
wssix99's Avatar
From the overflow tank? If so, a bad head gasket is a common cause. First thing to do is pressure test the coolant system.
Old 05-05-2011, 12:50 AM
johnzss's Avatar
I am going to swap out the thermostat first and see if that does anything. I really hope its not a blown head gasket.
Old 05-05-2011, 11:07 AM
Save the manuals!
wssix99's Avatar
The thermostat has noting to do with pressure in the system.
You should be able to rent a pressure tester from your local auto parts store for free.
