Abs inop and tsc light keep coming on
Old 10-15-2011, 06:38 AM
FOSTER21's Avatar
Default Abs inop and tsc light keep coming on
99 z28 and i hate lights being on
Old 10-15-2011, 07:59 AM
02_camaroz28's Avatar
Check all you speed sensors and wiring to start.
Old 10-15-2011, 08:35 AM
MidknyteRacer's Avatar
have you changed tires recently? Those are two totally different problems in a sense, something is triggering all that mess. There was just a thread about this under Wheels/Tires, clicky click click before you post!!!
Old 10-15-2011, 08:37 AM
alexus6798's Avatar
If you are running bigger tires in the rear it will cause those lights...
Old 10-15-2011, 08:44 AM
https://ls1tech.com/forums/wheels-ti...-problems.html, hope this helps, posted a couple days ago, lol
Old 10-15-2011, 09:07 AM
FOSTER21's Avatar
just started recently and im getting a low trac light sometimes too havent changed tires. the brakes were pretty bad all around so i changed those thinking the low fluid was causing the lights but no change
Old 10-15-2011, 10:05 AM
Well, you can scan for codes I believe, that might help. Maybe having those bad brake pads contributed to something worse. You might have a bad sensor or motor somewhere. I once had to change out my passenger side ABS sensor, on my 98 Z28, when the light popped on one day and stayed on but didn't effect braking, just didn't have any abs active. When I did some online research, and found sensor is easy to locate on the rear end on a housing behind the rotor, and this is how I found my bad passenger side sensor, the little magnet on it was broken off. I was surprised though that little sensor was $100 from the dealer, no auto parts store had it stocked.
