Condenser out for engine removal?
Old 11-21-2011, 03:48 PM
pcruiser73's Avatar
Default Condenser out for engine removal?
For those of you who have taken the engine out the top in an f-body (01), do you need to take out the AC condenser for clearance or will just the radiator be suffice?
thanks
Old 11-21-2011, 05:08 PM
RARON455's Avatar
It sure makes it easier removing the condensor, that way you dont have to worry about crushing it,, but I would say that it can be done just be careful and take your time with some help also...
also remove both headers, I tried once to remove it with them on, and had to fight and cuss, and remove the passenger side header with the engine hung in the bay,, no fun. I am speaking from experience
Old 11-21-2011, 10:11 PM
pcruiser73's Avatar
Thanks for your reply, will heed advice. Did you pull just the engine or engine with tranny connected?
Old 11-22-2011, 07:45 AM
RARON455's Avatar
Just the engine,,I am not sure if the engine/trans can even fit out of the top together, I remove the trans, and its really not that bad, you gotta remove it at a pretty good angle or the balancer will hang on the core support.
